Proszę zaradźcie coś!
'Bascom-AVR ver.1.11.7.4
$regfile = "AT26DEF.DAT"
$crystal = 8000000
Ddrb = &B00001100
Portb = &B00001111
'Osccal = 238
'Osccal = 226
'Osccal = 210
'Osccal = 190
'Osccal = 162
'Osccal = 124
'Osccal = 65
Osccal = 65
Pllcsr = &B00000010
Pllcsr = &B00000111
Ocr1c = 225
Ocr1b = 128
'Tccr1b = &B01000010
'Tccr1b = &B01000011
'Tccr1b = &B01000100
Tccr1b = &B01000100
Tccr1a = &B00110000
Config Pina.0 = Output
Config Pina.1 = Output
Config Pina.2 = Output
Config Pina.3 = Output
Config Pina.4 = Output
Config Pina.5 = Output
Config Pina.6 = Output
Config Pina.7 = Input
Config Pinb.0 = Input
Config Pinb.1 = Input
A_seg Alias Porta.5
B_seg Alias Porta.6
C_seg Alias Porta.4
D_seg Alias Porta.3
E_seg Alias Porta.2
F_seg Alias Porta.1
G_seg Alias Porta.0
A_k Alias Pina.7
S1 Alias Pinb.0
S2 Alias Pinb.1
Declare Sub Cyfry(cyfra As Byte)
Dim Cyfra As Byte
Dim Ocr As Byte
Dim Czas As Word
'GŁÓWNA PĘTLA PROGRAMU
If S1 = 0 Then
Waitms 100
Cyfra = 11
Call Cyfry(cyfra)
Do
Loop Until S1 = 1
Waitms 100
Readeeprom Cyfra , 1
If Cyfra > 9 Then Cyfra = 0
Call Cyfry(cyfra)
Do
If S1 = 0 Then
Waitms 100
Incr Cyfra
If Cyfra > 9 Then
Cyfra = 0
End If
Call Cyfry(cyfra)
Do
Loop Until S1 = 1
Waitms 100
End If
Loop Until S2 = 0
Waitms 100
Do
Loop Until S2 = 1
Waitms 100
Writeeeprom Cyfra , 1
Cyfra = 12
Call Cyfry(cyfra)
Wait 1
End If
If Cyfra > 9 Then Cyfra = 1
Call Cyfry(cyfra)
Select Case Cyfry
Case 1 :
Osccal = 128 '100Hz
Tccr1b = &B01001100 '100Hz
Case 2 :
Osccal = 128 '200Hz
Tccr1b = &B01001011 '200Hz
Case 3 :
Osccal = 204 '300Hz
Tccr1b = &B01001011 '300Hz
Case 4 :
Osccal = 128 '400Hz
Tccr1b = &B01001010 '400Hz
Case 5 :
Osccal = 175 '500Hz
Tccr1b = &B01001010 '500Hz
Case 6 :
Osccal = 176 '1k
Tccr1b = &B01001001 '1k
Case 7 :
Osccal = 176 '2k
Tccr1b = &B01001000 '2k
Case 8 :
Osccal = 116 '3k
Tccr1b = &B01000111 '3k
Case 9 :
Osccal = 176 '4k
Tccr1b = &B01000111 '4k
Case 0 :
Osccal = 210 '5k
Tccr1b = &B01000111 '5k
End Select
Tccr1a = &B00010001
Ocr = 128
Do
If S2 = 0 Then
If Czas < 6000 Then Waitms 40
If Ocr < 225 Then Incr Ocr
Czas = 0
Do
Incr Czas
Loop Until S2 = 1 Or Czas = 6000
End If
If S1 = 0 Then
If Ocr > 0 Then Decr Ocr
Czas = 0
Do
Incr Czas
Loop Until S1 = 1 Or Czas = 6000
End If
Ocr1b = Ocr
Loop
Select Case Cyfra
Case 0 :
If A_k = 0 Then
A_seg = 1
B_seg = 1
C_seg = 1
D_seg = 1
E_seg = 1
F_seg = 1
G_seg = 0
Elseif A_k = 1 Then
A_seg = 0
B_seg = 0
C_seg = 0
D_seg = 0
E_seg = 0
F_seg = 0
G_seg = 1
End If
Case 1 :
If A_k = 0 Then
A_seg = 0
B_seg = 1
C_seg = 1
D_seg = 0
E_seg = 0
F_seg = 0
G_seg = 0
Elseif A_k = 1 Then
A_seg = 1
B_seg = 0
C_seg = 0
D_seg = 1
E_seg = 1
F_seg = 1
G_seg = 1
End If
Case 2 :
If A_k = 0 Then
A_seg = 1
B_seg = 1
C_seg = 0
D_seg = 1
E_seg = 1
F_seg = 0
G_seg = 1
Elseif A_k = 1 Then
A_seg = 0
B_seg = 0
C_seg = 1
D_seg = 0
E_seg = 0
F_seg = 1
G_seg = 0
End If
Case 3 :
If A_k = 0 Then
A_seg = 1
B_seg = 1
C_seg = 1
D_seg = 1
E_seg = 0
F_seg = 0
G_seg = 1
Elseif A_k = 1 Then
A_seg = 0
B_seg = 0
C_seg = 0
D_seg = 0
E_seg = 1
F_seg = 1
G_seg = 0
End If
Case 4 :
If A_k = 0 Then
A_seg = 0
B_seg = 1
C_seg = 1
D_seg = 0
E_seg = 0
F_seg = 1
G_seg = 1
Elseif A_k = 1 Then
A_seg = 1
B_seg = 0
C_seg = 0
D_seg = 1
E_seg = 1
F_seg = 0
G_seg = 0
End If
Case 5 :
If A_k = 0 Then
A_seg = 1
B_seg = 0
C_seg = 1
D_seg = 1
E_seg = 0
F_seg = 1
G_seg = 1
Elseif A_k = 1 Then
A_seg = 0
B_seg = 1
C_seg = 0
D_seg = 0
E_seg = 1
F_seg = 0
G_seg = 0
End If
Case 6 :
If A_k = 0 Then
A_seg = 1
B_seg = 0
C_seg = 1
D_seg = 1
E_seg = 1
F_seg = 1
G_seg = 1
Elseif A_k = 1 Then
A_seg = 0
B_seg = 1
C_seg = 0
D_seg = 0
E_seg = 0
F_seg = 0
G_seg = 0
End If
Case 7 :
If A_k = 0 Then
A_seg = 1
B_seg = 1
C_seg = 1
D_seg = 0
E_seg = 0
F_seg = 0
G_seg = 0
Elseif A_k = 1 Then
A_seg = 0
B_seg = 0
C_seg = 0
D_seg = 1
E_seg = 1
F_seg = 1
G_seg = 1
End If
Case 8 :
If A_k = 0 Then
A_seg = 1
B_seg = 1
C_seg = 1
D_seg = 1
E_seg = 1
F_seg = 1
G_seg = 1
Elseif A_k = 1 Then
A_seg = 0
B_seg = 0
C_seg = 0
D_seg = 0
E_seg = 0
F_seg = 0
G_seg = 0
End If
Case 9 :
If A_k = 0 Then
A_seg = 1
B_seg = 1
C_seg = 1
D_seg = 1
E_seg = 0
F_seg = 1
G_seg = 1
Elseif A_k = 1 Then
A_seg = 0
B_seg = 0
C_seg = 0
D_seg = 0
E_seg = 1
F_seg = 0
G_seg = 0
End If
Case 11 :
If A_k = 0 Then
A_seg = 1
B_seg = 0
C_seg = 0
D_seg = 1
E_seg = 0
F_seg = 0
G_seg = 1
Elseif A_k = 1 Then
A_seg = 0
B_seg = 1
C_seg = 1
D_seg = 0
E_seg = 1
F_seg = 1
G_seg = 0
End If
Case 12 :
If A_k = 0 Then
A_seg = 0
B_seg = 1
C_seg = 1
D_seg = 0
E_seg = 1
F_seg = 1
G_seg = 1
Elseif A_k = 1 Then
A_seg = 1
B_seg = 0
C_seg = 0
D_seg = 1
E_seg = 0
F_seg = 0
G_seg = 0
End If
End Select
End Sub
End
