Wyświetlenie 4 liczb na LCD 4x16, fullTEXT
lukashb
Post autor: lukashb » 03 paź 2009, 21:10
Witam! Przyszedłem do Was po pomoc po raz 1, i mówię dzień dobry (dobry wieczór? :) )ale do rzeczy, mam urządzenie, któro dekoduje mi liczby, i je otrzymuję na LCD w wyniku operacji LCD Sequnce oto kod
$regfile = "m8def.dat"
$crystal = 14318000
Ddrd = &B00000000
Portd.2 = 1
' Config Lcdpin = Pin , Db4 = Portc.0 , Db5 = Portc.1 , Db6 = Portc.2 ,
Cursor Off
Config Timer1 = Timer , Prescale = 1 , Capture Edge = Rising , Noise Cancel = 1
Config Aci = On , Compare = On , Trigger = Rising
On Icp1 Oncapture
Enable Icp1
On Int0 Ontaster
Config Int0 = Falling
Enable Int0
Enable Interrupts
Deflcdchar 0 , 7 , 7 , 7 , 7 , 7 , 7 , 7 , 7       '   | prawy
Deflcdchar 1 , 28 , 28 , 28 , 28 , 28 , 28 , 28 , 28       ' |   lewy
Deflcdchar 2 , 31 , 31 , 31 , 32 , 32 , 32 , 32 , 32       ' -  góra
Deflcdchar 3 , 32 , 32 , 32 , 32 , 32 , 31 , 31 , 31       '- dół
Deflcdchar 4 , 3 , 7 , 7 , 14 , 14 , 28 , 28 , 28       ' /góra
Deflcdchar 5 , 7 , 7 , 7 , 14 , 14 , 28 , 28 , 24       ' /dół
Deflcdchar 6 , 24 , 28 , 28 , 14 , 14 , 7 , 7 , 7       ' \góra
Deflcdchar 7 , 28 , 28 , 28 , 14 , 14 , 7 , 7 , 3           '\dół
Declare Sub Drukujcyfre(byval Pozycja As Byte , Byval Cyfra As Byte)
Dim A As Byte
Dim B As Byte
Dim C As Word
Dim D As Byte
Dim E As Word
Dim I As Byte
Dim J As Byte
Dim K As Byte
Dim L As Byte
Dim M As Byte
Dim N As Byte
Dim Count1 As Word
Dim Icr_new As Word
Dim Icr_old As Word
Dim Freqlong As Long
Dim Freq As Word
Dim Timesample(10) As Word
Dim Freqsum As Word
Dim Samplenr As Integer
Dim Freqaverage As Word
Dim Frequpper As Word
Dim Freqlower As Word
Dim Tone As String * 1
Dim Toneeold As String * 1
Dim Sequence As String * 15
Dim Message As String * 15
Dim Timeout As Word
Locate 4 , 1
Cls
Main:
Portb.1 = 0
Portb.2 = 0
Waitms 0.6
Freqlong = 14318000 / Icr_new
Icr_new = 0
Freq = Freqlong
Incr Timeout
If Timeout = 60 Then
  Sequence = ""
  Toneeold = ""
  Message = ""
  Timeout = 0
End If
Timesample(10) = Timesample(9)
Timesample(9) = Timesample(8)
Timesample(8) = Timesample(7)
Timesample(7) = Timesample(6)
Timesample(6) = Timesample(5)
Timesample(5) = Timesample(4)
Timesample(4) = Timesample(3)
Timesample(3) = Timesample(2)
Timesample(2) = Timesample(1)
Timesample(1) = Freq
Freqsum = 0
For Samplenr = 1 To 10
  Freqsum = Freqsum + Timesample(samplenr)
Next
Freqaverage = Freqsum / 10
Frequpper = Timesample(1) + 20
Freqlower = Timesample(1) - 20
If Freqaverage > Freqlower And Freqaverage < Frequpper Then
  Select Case Freqaverage
      Case 1109 To 1139 : Tone = "1"
      Case 1182 To 1212 : Tone = "2"
      Case 1260 To 1290 : Tone = "3"
      Case 1343 To 1373 : Tone = "4"
      Case 1431 To 1461 : Tone = "5"
      Case 1525 To 1555 : Tone = "6"
      Case 1625 To 1655 : Tone = "7"
      Case 1732 To 1760 : Tone = "8"
      Case 1845 To 1875 : Tone = "9"
      Case 1961 To 1991 : Tone = "0"
      Case 2090 To 2130 : Tone = "E"
    Case Else : Goto Main
  End Select
Else : Goto Main
End If
If Tone = Toneeold Then Goto Main
Timeout = 0
If Tone = "E" Then
Sequence = Sequence + Toneeold
Else
End If
Toneeold = Tone
If Len(sequence) >= 5 Then
 cls
LCD Sequence
      Portd.4 = 1
 End If
Goto Main
Ontaster:
Portb.1 = 0
Portb.2 = 0
Cls
Lcd "CCIR-dekoder"
End Sub
Oncapture:
  Count1 = Timer1
  Icr_new = Count1 - Icr_old
  Icr_old = Count1
  Portb.1 = 1
  Portb.2 = 1
Return
i chciałbym teraz ten wynik zamienić na duże liczby wykorzystując do tego LCD 4x16
dostałem od kolegi z forum działający program który pokazuje zliczanie od 1999 do 9999 właśnie w takim formacie, przerobiliśmy go trochę, i efekt jest taki, że u mnie są same zeraz albo nie pełne zera, lecz wyniku brak, oto efekt przeróbki
$crystal = 14318000
Ddrd = &B00000000
Portd.2 = 1
Cursor Off
On Icp1 Oncapture
Enable Icp1
On Int0 Ontaster
Enable Int0
Enable Interrupts
Dim A As Byte
Dim B As Byte
Dim C As Word
Dim D As Byte
Dim E As Word
Dim I As Byte
Dim J As Byte
Dim K As Byte
Dim L As Byte
Dim M As Byte
Dim N As Byte
Dim Count1 As Word
Dim Icr_new As Word
Dim Icr_old As Word
Dim Freq As Word
Dim Freqsum As Word
Dim Timeout As Word
Locate 4 , 1
Cls
Main:
Portb.1 = 0
Portb.2 = 0
Waitms 0.6
Icr_new = 0
Freq = Freqlong
Incr Timeout
  Sequence = ""
  Toneeold = ""
  Message = ""
  Timeout = 0
End If
Freqsum = 0
Next
  End Select
Else : Goto Main
End If
Timeout = 0
If Tone = "E" Then
Else
End If
Toneeold = Tone
      C = Val(sequence )
      For B = 1 To 4
         Select Case B
            Case 1 :
                 E = C / 1000
                 D = E
            Case 2 :
                 E = C Mod 1000
                 E = E / 100
                 D = E
            Case 3 :
                 E = C Mod 100
                 D = E / 10
            Case 4 :
                 E = C Mod 10
                 D = E
         End Select
         Call Drukujcyfre(b , D)
      Next B
      Portd.4 = 1
 End If
Goto Main
Ontaster:
Portb.1 = 0
Portb.2 = 0
Cls
Lcd "CCIR-dekoder"
    M = Pozycja - 1
    M = M * 4
    M = M + 1
     For I = 1 To 4
         Locate I , M
         For J = 0 To 3
             N = Cyfra * 16
              K = I - 1
              K = K * 4
              K = K + J
              K = K + N
              L = Lookup(k , Cyfry)
              Lcd Chr(l)
         Next J
     Next I
End Sub
'kody cyfr
'0 to znak wczytany wcześniej do wyświetlacza z użyciem deflcdchar
'32 to znak pusty znajdujący się w ROM wyświetlacza
Cyfry:
'0
Data 32 , 4 , 2 , 6
Data 32 , 1 , 32 , 0
Data 32 , 7 , 3 , 5
'1
Data 32 , 32 , 4 , 1
Data 32 , 4 , 32 , 1
Data 32 , 32 , 32 , 1
'2
Data 32 , 4 , 2 , 6
Data 32 , 32 , 32 , 5
Data 32 , 32 , 4 , 32
Data 32 , 4 , 3 , 3
'3
Data 32 , 4 , 2 , 6
Data 32 , 32 , 3 , 5
Data 32 , 32 , 32 , 6
Data 32 , 7 , 3 , 5
'4
Data 32 , 2 , 2 , 1
'5
Data 32 , 0 , 2 , 2
Data 32 , 0 , 3 , 32
Data 32 , 7 , 3 , 5
'6
Data 32 , 4 , 2 , 6
Data 32 , 1 , 32 , 32
Data 32 , 4 , 2 , 6
Data 32 , 7 , 3 , 5
'7
Data 32 , 2 , 2 , 4
Data 32 , 4 , 32 , 32
'8
Data 32 , 4 , 2 , 6
Data 32 , 7 , 3 , 5
Data 32 , 4 , 32 , 6
Data 32 , 7 , 3 , 5
'9
Data 32 , 4 , 2 , 6
Data 32 , 7 , 3 , 5
Data 32 , 32 , 32 , 0
Data 32 , 7 , 3 , 5
Return
Oncapture:
  Count1 = Timer1
  Icr_old = Count1
  Portb.1 = 1
  Portb.2 = 1
Return
i pytanie, dlaczego ten program nie wyświetla sequence, przecież ten kawałek kodu
C = Val(sequence )
      For B = 1 To 4
         Select Case B
            Case 1 :
                 E = C / 1000
                 D = E
            Case 2 :
                 E = C Mod 1000
                 E = E / 100
                 D = E
            Case 3 :
                 E = C Mod 100
                 D = E / 10
            Case 4 :
                 E = C Mod 10
                 D = E
         End Select
      Next B
ma za zadanie przekształcić dane na taki format wywołując odpowiednio procedury Drukujcyfre itp, teoretycznie powinno działać, a niechce, wszelkie zmienne są na początku, amoże ktoś ma sprawdzony pomysł i pomógł by przerobić ponieważ siedzę nad tym już 3 dzień i 0 efektów, a bardzo mi zależy. Pozdrawiam Łukasz
Edit: poprawiłem znaczniki Code. Ddevil
Ostatnio zmieniony 04 paź 2009, 14:13 przez lukashb, łącznie zmieniany 1 raz.
