AVR programowanie ISP
kaliska5
Post autor: kaliska5 » 03 lut 2012, 19:56
Witam.Próbuje uruchomić procedurę programowania szeregowego w Atmega64 i nijak nie chce ruszyć.Korzystam ze źródeł USBasp.Korzystam z programowego SPI na porcie D.
isp.h:
#define	ISP_OUT   PORTD
#define ISP_IN    PIND
#define ISP_DDR   DDRD
#define ISP_RST   PD5
#define ISP_MOSI  PD6
#define ISP_MISO  PD3
#define ISP_SCK   PD4
i prototypy funkcji
Plik isp.c wygląda tak:
#include <avr/io.h>
#include "isp.h"
#include "clock.h"
uchar sck_sw_delay=100;
uchar sck_spcr;
uchar sck_spsr;
void ispDelay() {
	uint8_t starttime = TIMERVALUE;
	while ((uint8_t) (TIMERVALUE - starttime) < sck_sw_delay) {
void ispConnect()
	DDRD = 0x00;
	ISP_DDR |= (1 << ISP_RST) | (1 << ISP_SCK) | (1 << ISP_MOSI);
	ISP_OUT &= ~(1 << ISP_RST); /* RST low */
	ISP_OUT &= ~(1 << ISP_SCK); /* SCK low */
	ispDelay();
	ISP_OUT |= (1 << ISP_RST); /* RST high */
	ispDelay();
void ispDisconnect() {
	/* set all ISP pins inputs */
	ISP_DDR &= ~((1 << ISP_RST) | (1 << ISP_SCK) | (1 << ISP_MOSI));
	/* switch pullups off */
	ISP_OUT &= ~((1 << ISP_RST) | (1 << ISP_SCK) | (1 << ISP_MOSI));
uchar ispTransmit(uchar send_byte) {
	uchar rec_byte = 0;
	uchar i;
	for (i = 0; i < 8; i++) {
		/* set MSB to MOSI-pin */
		if ((send_byte & 0x80) != 0) {
			ISP_OUT |= (1 << ISP_MOSI); /* MOSI high */
		} else {
			ISP_OUT &= ~(1 << ISP_MOSI); /* MOSI low */
		/* shift to next bit */
		send_byte = send_byte << 1;
		/* receive data */
		rec_byte = rec_byte << 1;
		if ((ISP_IN & (1 << ISP_MISO)) != 0) {
			rec_byte++;
		/* pulse SCK */
		ISP_OUT |= (1 << ISP_SCK); /* SCK high */
		ispDelay();
		ispDelay();
	return rec_byte;
uchar ispEnterProgrammingMode()
	uchar check;
	uchar count = 6;
	while (count--) {
		ispTransmit(0xAC);
		ispTransmit(0x53);
		check = ispTransmit(0);
                lcd_hex(check);
		ispTransmit(0);
		if (check == 0x53) {
			return 0;
		/* pulse SCK */
		ispDelay();
		ispDelay();
	return 1; /* error: device dosn't answer */
W głównym programie wywołuje najpierw
ispConnect()
jakasdana=ispEnterProgrammingMode
Cały czas otrzymuje w 3 bajcie 0xFF.Nie mogę użyć sprzętowego SPI ponieważ musiałbym robić nowa płytkę .Czy ktoś programował AVR tym sposobem i podzieliłby się spostrzeżeniami co robię źle ?
